Hard race rear : Camber arm, toe arm, thrust arm and lca (lower control arm)
That is one bad *** suspension setup, can't beat KW coil overs. I had them on my S4 and it rode smoother over bumps and seemed to be sucked more to the ground that what the stock suspension provided. Definitely worth the $2000+ to get those coil overs.
As for the new arms, those look sick as hell also. Your friend has good taste and deep pockets.
We both ran identical setups (Except the lca wasnt around when I ordered everything else) I just put in the order for the megan LCA
![](https://sphotos.xx.fbcdn.net/hphotos-snc6/263516_215570221815409_100000872993119_578513_4495579_n.jpg)
That must have been for the IS200/IS300, because I don't see one here :
http://www.hardrace.com/products.asp...5&strClass3=75
Bring this back to life.
Anyone got this ?? Recently just found a source for these. They're made in Taiwan, Megans are probably made in Taiwan too. Guessing they're the same stuff but different sticker? Those bushings looks good though would be a good alternative to Figs
