supra calipers
have a friend who just upgraded his brakes on his supra, so he has the old supra front calipers and rotors. and i see that people upgrade to these on the gs is it a direct bolt on or is there an adapter of some sort that is needed for the larger caliper.
tks, larry
tks, larry
your friend supra have to be the stock tt version, not the NA version. direct bolt on the gs. unless your have stock 17" or 16, then it's won't fit w/o wheel spacer or cutting on the caliper.
Not sure if it helps or not, but the RMM (Rod Millen) brake upgrade is actually right off the supra...so this will work...like stated before, only if the Supar is a TT...
-KRis
-KRis
Benjamin T
Suspension and Brakes
08-15-07 12:11 PM
