DIY: Remove stock abs/vsc master cylinder ---> Install power brake booster & master
I am having a problem with the buzzing I am receiving from my ABS VSC TRAC and BRAKE light that goes on. Dealers tell me its a $1200 fix. I dont mind driving without those keen options but I cannot seem to find the buzzer that you are talking about. I have gone in depth looking under the steering column but can't pinpoint where the buzzer noise is coming from... Any navigation tips on how to find it or possibly a picture of where the thing is? Any help is appreciated, thanks!
If you ignore the issue and have brake failures, you put whoever is in that car and the people around the car in danger...if brakes fail and cause an accident.
You can find 2nd hand masters for a 1/3 the price you were quoted. I also suggest upgrading to a 2001 and newer master.
AMSMIKE,LOVE THE RIGHT UP ABOUT THE BRAKE CONVERSION DO YOU THINK THIS WOULD BE A GOOD SET UP FOR A REGULAR DAILY DRIVER IN CASE MY ABS TAKES A SH-T ALSO I NOTICE THE RED CAR YOU DID HAS A DIFFERANT MASTER CYLINDER ON IT..
THANKS,JOHN
THANKS,JOHN
The red GS has a JDM Supra MKIV master bolted to the Avalon booster.
Sorry to bring this thread back from the dead AMSMIKE but in this picture isn't there a prop valve on the brake master? I know for the Brake Master that looks like that the prop valve is integrated into the brake master unit. So from the picture it looks as though now you have two prop valves (factory and wilwood).
The brake master in the red car may have a built in prop valve, but it will be calibrated to the car it came from, not the car it is going in. You'll still need to balance the braking to avoid the rears locking up first under hard braking. Then you spin. If your setup works fine, under hard braking the fronts still lock up just before the rears. If you stop hard and the rears lock up first, you put the proportioning valve in and reduce the pressure to the rears until that stops happening. If you make your front brakes better, they will take up more of the weight of the car, and the rears will overpower the reduced load and lock. If you improve your rear brakes, they will do this faster! The tires can only handle so much weight and braking before they lose traction.
BTW, I know this is an old thread but I wanted to update the info on the master cylinder since I just made this mistake. The 2000 m/y avalon uses a different brake master and the same power booster. I ordered all new parts, and when I got the 2000 avalon MC it is slanted heavily and very long. Won't work. Looking at a variety of pictures, the 98 avalon uses a straight design and is the one in Mikes pictures. Order the 98 avalon master / booster to be sure. Only costing me a few $$ in return shipping though, I'll live. Changed to 98 from 99, since 99 looks like the turnover year and the booster I received is wrong. All 98 parts look correct.
2000 avalon brake MC
![](http://images1.carpartsdiscount.com/auto/archive/pictures/296132/515/1/P/9F4DF8B/toyota_avalon_2000_brake_master_cylinder_oem_072_9509_729509.jpg)
1998 avalon brake MC cardone 13-2735
![](http://www.carid.com/images/wp/advics/w01331609619adv.jpg)
98 avalon booster, make sure all your parts look like these photos or you'll be sad. Cardone 53-2766
![](http://my.cardone.com/Imagesftp/53/532766-01.jpg)
Hey was wondering where you T into your vacuum system for vacuum supply to the new booster unit? I wasn't sure if I should T into the PCV line cause then vacuum supply would be less sufficient to both locations. Any input would be great, thanks.
