HELP! Suspension Noise From Front End *VIDEOS INCLUDED*
Mine ended up being the caster arm bushings, the ones I replaced two years ago with Daizens. I think the Daizen design is pretty crappy. I went back to OEM type bushings and it has been smooth as silk ever since.
Thanks Again
My noise sounded exactly like yours, so hopefully this will do it. If you have the original caster arm bushings, I guarantee you that they are shot at this point.
Alrighty! Btw fixed the problem it happened to be worn out top hats back in July 2012 I installed Megan EZ streets, new mooj lower ball joints and mooj outer tie rods, problem solved! All the sounds went away. Good luck to you all
Where the rubber top hats broken when you removed them?
This is very rare as the rubber top hats typically last a long time.
Sorry I forgot to mention, It was the OEM strut suspension that has been replaced with the Megan EZ's back in July which solved my problems. The EZ's don't come with rubber top hats.
Megan EZ come with rubber top hats on a blue aluminum plate.
Megan LP come with solid top hats on a reddish aluminum plate.
Am I not remembering correctly or did you forget to leave in your caster arm sleeves when you installed your Daizen caster bushings?
