Eibach Pros - front sits too low (V8 swap). Suggestions on something 1" taller?
Unless you go with bilstein shocks it has an adjustable c clip you can move 1/4" up or down
And if you have machine shop cut more notches in the shock the possibilities are endless...
Bilstein can not only rebuild your shocks, but also build a custom setup like going shorter stroke and increased damping for higher rate race springs.
They ride very comfortable at slow speeds, but as speed increased they become firmer and sportier. I bet with eibachs it would be an awesome combo! I have tein spring now and i like it, but I think I want to go a with like 800lb+ springs now
Good luck
Good luck
Mr.NA_T
Performance & Maintenance
02-10-08 01:25 AM
