Eibach Pros - front sits too low (V8 swap). Suggestions on something 1" taller?
I am running Eibach Pros with Tokico Blues and the front is sitting 1" too low. I am sure this is due to the extra weight of my motor swap, turbo, etc... My tires scrub lightly on hard turns and it will bottom out on occasion on heavy dips in the road. It rides fine but gets annoying!
The rear sits perfect so I don't need to swap those.
I no longer have my OEM springs. Any other suggestions?
Thanks,
David
Thanks,
David
I'll verify the P/N... thanks!
That's the part number for the SC300 pro-kits which will drop the car maybe .5" lower up front because of the extra weight of your motor. I'm running the same springs on my SC400 but they didn't drop as low as yours up front. The front shocks might be blown already if it's bottoming out easily. I installed mine on the stock shocks which have about 54,000 miles on them and they haven't bottomed out on my drives so far *knocks on wood*
I have had experience with the Tokico blues and they do wear out pretty quickly compared to the stock struts so I am guessing that would be the problem with your car.
