Left & Right axles blown at 50k PLEASE HELP
Though I don't follow alot of the 2IS AWD threads, I have read enough to know that AWD owners say that lowering the cars cause excessive strain on the half shafts and cause pre-mature wear/breakage.
When you change the boot, you clean all of the old grease out and put new grease in. It is not a band-aid fix unless components are already damaged. As for why you would do one and not the other, well that's usually cost based.
I'd rather keep my factory axle with a new factory boot than put in an aftermarket axle.
Jeff
Jeff
The cost of labor, is most likely going to be the same for replacing boots or replacing the whole axle (not including the cost of parts). In order for them to change the boots, they have to take out the axle, remove the joint and then replace the boot. Yes they will add new grease. But if you dont know the condition of the joint itself, replacing only the boot is risky. It might already be damaged ( it doesnt have to click or make noise). And then one day you will have to replace the axle, and pay more labor cost to do it. Then you have to get another alignment and pay more.
So what do you think I should do? I dont think this is covered under the powertrain warrenty. Could I ***** at coperate to see if they will cover it or atleast pay half?
On another note you say I just can repair the boots right? I may be giving up the car in a year so If I can save money thats what I would like to
Dealers love to blame aftermarket components. They might be right this time, but its not unheard of for dealers to blame engine problems on a aftermarket muffler, which is nonsense. Or the can claim that the aftermarket components void the warranty and so forth. So Yes, I would reinstall OEM components before heading to the dealer.
If your good on taking pictures (safely)... Shows what you got..!!!!
Im curious to see if its the hubs giving you issues and NOT the axles....
Of course verifying a "torn boot" would be good to do as well..!!
~ Joe Z
~ Joe Z
also if decide to get new axles, know that its really not new. they are remanufactured. basically they take the olds ones and rebuild them, then resale them
i wouldn't say coils is the cause but it can cause it to wear out faster. thats the thing about modding cars, things tend to wear faster!!! (supension and engine performace upgrades)
If its one thing i absolutely hate is when someone suggests to "take off the aftermarket part and go to the dealer!"... essentially defrauding the dealer and warranty. If lowering the car put undue stress on the boots, then own up to it and fix it out of your own pocket, dont expect Lexus to cover it. Especially when you dont do your services there. If the coils didnt cause the failure, then it should be warranty. Should be pretty easy to tell if the car is up on a flat rack, you can see the angle of the cv joint and tell if its going to cause damage. You said the car has only been lowered for 10k miles... im assuming it wasnt leaking prior to that. I can honestly say that leaking CV boots are extremely rare in the IS, whether it be 2WD or AWD... Let the dealer take a look at it. Dont instantly threaten to call corporate... both the dealer and corporate will not take you seriously... especially with no service history and aftermarket parts installed.
So what does everyone think around here? is it 50/50 that lowering your car could put stress on the boots? I heard about boots leaking and what not on here before. If someone can tell me that the lowering is to blame I will bring it back to stock. Ill be bringing it to the dealer this week. Never told the guy im lowered on coils but he saw the car and know its low. I will just wait to they say something to me about it
Ive had my is serviced before being modded. If they determine the problem is from the coils then they won't cover it. I've been lowered since about 10k miles and my car has about 84k now and it still runs perfectly.
