Changing Brake Pads and Rotors, Brake Bleeding and Flush Question
Hi there,
Got all 4 Slotted rotors and Hawk brake pads, now I just got a brake flush and free'd the seize caliper I had the other day, and I'm going to install the rotors and pads soon, after installing them would I need to bleed my brakes again? Also do I have to bed the pads in?
Thank you
Thank you
If you bleed it properly after replacing the seized calipers and changing fluid then your good, bleed not required with just a pad/rotor change.
Some pad manufactures say no bedding is needed, check thier specs. With a new rotors and pads at the same time I would bed them tho, weather it says it is required or not.
I researched slotted and drilled rotors. Better to have ones that are smooth. Once you install them report back on any air noise they make. I would change the fluid regardless. You should change the fluid every time you change your pads so you have fresh fluid in there.
tuxlexus
RX - 1st Gen (1999-2003)
20
11-20-06 01:07 PM
DroppedGS
01-15-05 12:49 AM
