Front brake rotor ?
Front brake rotor ?
Is250 2006 : the dealer told me that I need a brake service and that the front brake rotor needs to be replace too since you cannot turned the disk like a particular car . True ? If so can I just replace the pads and be okay ? Dealer Quoted me at 500$ just for the front .
Possibly about multiple things.
You certainly can turn the rotors, but unless there's something seriously wrong with them you're just wasting good metal to do so.
If the rotors are in good shape (does the car brake and stop smoothly now? if so they're likely fine) they yeah just slap on new pads and go.
Heck you might not even REALLY need new pads as they'll often say you do long before you actually do.
FInd out the measurement of the remaining pad from them... 1 mm is min spec.
yeah that is exactly what i thought. the front specs are 6mm and the rear are currently at 3mm. the car brakes smoothly still , just getting a fine random squeeking noise from the rear from time to time.. so i will just buy pads on the outside and possibly just do the job myself. thanks guys
So squealing brakes don't necessarily indicate a real problem with your brake system on this car from my experience. When your pads are low, the wear indicators will make a noise which apparently is quite different from the squealing that I think you're talking about.
Well I have about 45K on my front brakes, and they just now are about ready to be replaced (the pads at least, not yet sure about the rotors -- I suspect the rotors still have some life left to give) and over 60K on my rear brakes, and they still have like 20% of their life left.
Bullskim
Suspension and Brakes
18
08-12-09 07:24 AM
Fizzboy7
12-31-08 02:29 PM
is250gurl
09-07-07 09:09 AM
