Where to buy polyurethane bushings?
Okay so I have emailed tm engineering and swell Lexus countless times with no response. So my question is where can I get polyurethane bushing kit to replace all the stock bushings. This is for a 02 gs300. Thanks
I haven't heard of an "all bushing" replacement kit... Someone chime in if there is one. These cars have a bunch of different bushings and i've only seen them listed for specifics. Sewell are poly and great. Im pretty new to all this but i haven't heard of an all bushing kit
please search next time guys, this is just ONE of 100+ threads on TM
https://www.clublexus.com/forums/sit...cl-vendor.html
TM has them their customer service sucks but eventually after you pay you get your item. if they are in stock todd ships immediately if not dont bug him. the more you bug him the longer it takes....took me almost 60 days after payment to get mine
Noone else makes a complete kit sewell,carson have OEM style replacements for the castor arm and FIGS has a spherical bushing replacements for the castor arm.
these are the ones most people want/need anyways is the castor arm bushing
Front:
Get new shocks, and/or springs, coilovers, or air.
1. castor arms also known as lower control arm #2 or replacement bushings (daizen, figs, roca, trd) $360 new arms/$275 figs
2. lower control arm #1 or replacement bushings $350
3. upper control arm (adjustable if needed) or upper control arm bushings $650/$400
4. sway bar end links $180
5. sway bar bushings $15
6. steering rack bushings $45
7. new steering rack lol
8. lower ball joints $190
9. outer tie rods $145
10. inner tie rods $300
Rear
1. Adjustable toe rod $200
2. Adjustable traction rod $115
3. adjustable upper control arm or upper control arm bushings $500+/$???
4. lower trailing arm bushings (trd) $150
5. upper trailing arm bushing $150
6. sway bar links $150
7. sway bar bushings $15
8. rear supra diff bushings (if needed) $150
9. center supp bearing for driveshaft (if you need to) $150
10. rear subframe bushings (if needed) ???
Hope that helps.
Also for the price of roca bushes, i'd go trd.
Rear
Hope that helps.
most of those parts especially the inner/outer tie rods can be had for HALF of his listed price but i agree good info on there...
read you vendor thread Sakataj above, and its long basically saying not to use TM. On that note does anyone know what the part no. for the caster arm bushings are from Sewell.? otherwise you have to search their parts list and i spent 10-15 minutes looking for the caster arm, and/or bushings with no luck. Thanks
i have or had ALL of daizen's bushings, the steering rack,swaybar bushings (gone now when i got my TRD's) and all the control arms. i know all about Todd @ TM. i even tried to become a dealer for daizen to bring them back into the limelight so to speak but it was not to be.....
no u dont, look on sewells site under service tab on the left of the year/make/model of your car, i just looked took me less than 1 minute to find it, they just call it a front trailing arm bushing or something like that. ALL major service items for the 2nd gen gs are in that quick tab
Found the Sewell Bushings thanks to your advice..... They appear to be the SAME as the Daizens..at least Polyurethane at least .. may already be some post about this.. haven't checked just yet
FIGS said these and the carson bushings arent developed well, all the pics people of them the bushings have TONS of air holes in them
You referring to these right?
Caster arm bushing: $67.94
537SET
http://lexus.sewellparts.com/accesso...2002/4685.html
