wheel shaking
so after my accident my driver side tire is shaking around 75mph ...im thinking because they didnt balance the new tire right? also those mother suckers...STRIPPED MY STUDS...
can i get some help maybe some insight its really irritating when driving
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
A few other ideas: The most obvious to me would be the car needs an alignment. Next, I'm assuming your tires are not worn on the inside or out? And finally, I had one vehicle with this problem where the ball joint was shot.
idk if you guys remember but i had a hit and run maybe 6 months ago. damage was to the driver side fender and slashed the tire. i had the fender and tire replaced . BUT NOW THERE IS A SHAKING i feel when going around 70-80mph . I had them balanced checked if they were bent and also alignment done twice. i need some help any advice im going crazy and im getting the run around
i have a is350 so not the same tech said it wasnt a bent rim or hub
so the vibration continues with the left driver side wheel
no bent rim
no bent hub
all bushing are good
so i thought it would be a hub centric ring
well no so much
vibrates at 80mph .?
any assistance just to figure it out
no bent rim
no bent hub
well no so much
