Rear lower control arm bushings???
Old 04-09-12, 10:14 AM
RoninEng
RoninEng's Avatar
Default Rear lower control arm bushings???
Hello, i just bought my car and for the most part its clean, needs reg maint. I noticed on the rear lowere control arms the bushing that attach to the hub have excessive play. What are these called and where should i get them? Thanks
Attached Thumbnails Rear lower control arm bushings???-rear-lower-bushing.jpg   Rear lower control arm bushings???-lower-bushing.jpg
Old 04-09-12, 02:41 PM
RoninEng
RoninEng's Avatar
search is your friend, but apparently i am wrong,
Old 04-09-12, 02:48 PM
justablkv8
justablkv8's Avatar
the is200 bushings you're looking for are the ones you need.
Last edited by justablkv8; 04-16-12 at 12:46 PM. Reason: thought he was talking about traction rods.
Old 04-09-12, 02:53 PM
RoninEng
RoninEng's Avatar
so the bushings that the long thread is about and noone can find are not what i need? what are these bushings then?
Old 04-16-12, 12:01 PM
justablkv8
justablkv8's Avatar
Sorry, thought you were looking for the traction rod bushing. Pic was kind of confusing. the bushings below are what you need.
trd makes them as well.
Old 04-16-12, 12:41 PM
sakataj
sakataj's Avatar
u do indeed need these bushings going by your first picture and second pic, that is
https://www.clublexus.com/forums/sus...placement.html
the bushings u need look like this
Originally Posted by justablkv8
You are better off just going with top speed, megan or figs traction rods.
so i know you think im following you but this is 100% purely coincidental i assure you,OP is referring to the rear control arm and not the trac links.....which don't come with a bushing either though so that still wouldn't fix his issue even if it was the right part.
OP if u need the trac links you would still need a replacement bushing which you could get here
http://www.l-tunedparts.com/product/?id=3322
but going from your first/second pic you need the Rear Axle Carrier Bushing from the thread i linked
Old 04-16-12, 12:48 PM
justablkv8
justablkv8's Avatar
You're right, I was misinterpreting the pics.
Old 04-16-12, 06:20 PM
RoninEng
RoninEng's Avatar
Sakataj, I am with you on what I need just insure where to get them. I tried the eBay seller and he never got back to me and rhd Japan does not specify which bushings
Old 04-17-12, 11:05 AM
sakataj
sakataj's Avatar
i may sell mine....i have my buddy shipping me some of the ones RHD sells direct from japan
Old 04-17-12, 01:25 PM
RoninEng
RoninEng's Avatar
Do you have the direct link for the rhd ones? Or a contact number so I can speak to someone and know they are correct?
Old 04-25-12, 02:56 PM
speed6
speed6's Avatar
just an fyi Battle Version now carries rear traction, toe and lower control arm. I know because i was over there buying more crap for my SC. he just finished up with the GS LCA, and saw them on the Apexi SC430 when i was over there, and they look badass!
Old 04-25-12, 03:57 PM
RoninEng
RoninEng's Avatar
Where can I pick them up?
Old 04-26-12, 09:40 AM
sakataj
sakataj's Avatar
as i said before......u still need the bushings for those which is what OP is trying to find (well actually he wants the bushings for the rear axle carrier) so these items dont do him any good
Old 06-25-12, 11:06 AM
RoninEng
RoninEng's Avatar
Figs bushings for this repair are great. Install was easy. This is kind of a repeat thread so mod can delete please. Thanks
Old 07-11-12, 08:30 PM
MonB
MonB's Avatar
Default Similar Issue
Hi Guys, I was wondering if someone could perhaps help me, i have a similar issue and I have a 2002 SC430 model and I am required to buy some Rear lower control arm bushes and i have been told they arnt available anything other than Japan and will cost approximately $800 each.
Would anyone know what part I should be buying, where i could perhaps buy it from and at what approximate cost ?
I just had this feeling i would be getting ripped off big time!
Cheers
MonB
Quick Reply: Rear lower control arm bushings???
