Shaking after replacing rotors and pads
So I just replaced the rotors and pads on my IS350 and tightened and cleaned everything in the process. I changed them because they were shaking so I assumed it was warped rotors. I did buy rotors from a member on here that said he had less then 1000 miles on them. The only thing I can think of is the rotors may have been damaged and warped in shipping. They weren't packaged very well ![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Before I call these rotors and pads a total loss and I'm out $150 bux is there anything else I'm missing?
Could I have put the pads in backwards? I am getting a brake squeal as well...I mean this isnt my first brake job and I made sure to reinsert the pin and cotter pin and tighten the caliper bolts.
I'm thinking it could be something else besides warped rotors that could be causing a shake while braking...hopefully
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Thats odd, usually warped rotors the only vibration you will feel is the brake pedal, it will feel like it's "skipping" when you apply the brakes. me. I hate to try and diagnose something over the internet but I am trying to help here don't mind the million questions.
Properly installed rotors do not warp. Really.
http://www.stoptech.com/technical-su...nd-other-myths
The fact you have the same symptoms before and after suggest it might be something else, but did you properly bed the new brakes?
I had zero shims with taking out the old pads. Do I need shims or are they necessary only if the rotor thickness is less then OE spec?
I just recently replace mines a month ago. cross-drilled slotted. after installation i took it out, went to 60mph slam on the brake til its almost to a complete stop but not all the way, then 40mph then 20mph to imbred "i think that how the spell it"
the pads onto the rotors. But in these case u bought a use part so i wouldn't know what to tell u. Check ur brake fluid, inspect all the lines. U may need to bleed master cylinder maybe. THIS IS WHY I HATE USE STUFF< THEY WANT TO SELL IT FOR A REASON!
