brake dust
Bad news: Unless you're still under warranty (which is unlikely, though still possible, for a 2007) you can't get it done for free.
Do a search, there's a bunch of threads on it. They replace the pads with ones that produce massively massively less dust.
If you're out of warranty you can still order the low dust pads from sewell and put em on. VAST improvement.
I thought TSIBs had to be honored regardless of whether you were within the warranty period, though.
Unless your dealership is completely incompetent and replaces the pads with the exact same pads (same part number as the original pads), and you notice it on the invoice, and you come back and tell them, and they insist it's right, and you show them the right part number and explain that your wheels are still dusting, too, and they take the car back and say they'll fix it this time, and they give you another invoice with the same effing part number. Then your wheels keep dusting until you just replace the damn things yourself.
You might be thinking of recalls, which are always free... but are usually major safety/reliability issues (like fuel pressure sensor might come loose and leak fuel/cause a fire for example).
Coconut
Suspension and Brakes
10-12-07 12:31 PM
