TRD springs?
they are special order from japan:
i think steve has them lised on the site
http://www.toyota-trd.com/en/strt/s_lowsprng.html
jzs161: 35mm, 1.4" drop
jzs160: 20 mm, 0.8" drop
price: JPY 40,000, ~$350/set
spring rate:
F:8.6 kg/mm
R:7.6 kg/mm
the higher the #, the stiffer the ride
spring rate:
F:8.6 kg/mm
R:7.6 kg/mm
I have the TRD springs...and the Shocks....however...I have noticed one thing with the "TRD" springs...they are actually the same as the Eibach springs...I have talked to different shops around the Chicago area and they too have confirmed that the Eibach springs are the same as the TRD ones...just some food for thought...
-Kris
-Kris
-Kris
-Kris
I mean, proof positive would be either TRD or Eiback confirming this, or seeing an Eibach designation onthe springs, right?
Originally posted by Dex
Kris, you info is interesting, and don't take this the wrong way, but how would they know?
-Kris
...see what these companys do is they sell the rights to the products....
But just someone looking at it and saying yep, these are the same... I have a difficult time buying.
I agree with you though; I bet they are the same.
based on the fact that the Eibach and TRD springs(the one for NA model, not jzs161 turbo) has almost similar drop, and all the springs out there has more drop, i would not be surprised if the TRD NA springs are the same as the eibachs...
BUT, TRD NA spring does have slightly different spring rate to that of eibachs
the again, this is my "conclusion" based on few facts, not 100% sure.
