Anyone replace their rear suspension bushings to Poly?
I notice that the IS200/300 guys have a simular rear hub + suspension arms like ours, if not the same, and they have lots of bushing kits to replace the old OEM rubber bushings.
Superpro makes all the bushings for the rear end for the IS... anyone try them out yet?
i can see my rear lower control arms are making some noise (at least i think they are) so maybe replacing the bushings could benefit?
they sell it all over ebay and FIGs has them for sell as well.
did your poly come with grease? squeeky bushings is a known problem however ive heard that if you initially and then continually grease them that the noise goes away
Yes I did but the sound doesn't go away. I am curious how you would continue to grease them after being installed??? I guess it is not too bad since it is my weekend warrior but I would use rubber bushing for a DD.
one trick is to cut notchs or ribs inside the bushing so it creates a pocket to pack grease in. not sure if thats good or not.
anyways my fronts poly daizens and i dont really notice a squeak at all. just my rear suspension where my oem bushings are worn
My castor bushings are poly and there isn't any noise, now that I think of it. I don't know if it is just because it is a honda or if it is because of multiple poly bushing just making everything more stiff.
Conceptvip
06-11-24 11:53 AM
