front end
i have a 2000 gs400 and im about to put a set of staggered lowenhart ldr wheels on it all of a sudden the front end feels like crap so i had it checked out and they said ball joints good but the 2 control arm bushings are bad will this make the car feel like something gonna fall apart and im also getting a rattle from my passenger side brake or caliper please post suggestions thanks in advance
What do you mean feels like crap? Noise? Clunks? Handling?
Umm get new bushings. As far as I know, you can get them from Sewell. Not sure about the brake calipers though. Bushings shouldn't hurt the pocket much if you can do the installation yourself.
I don't know much, but if a part is bad then just change it even if its not the source of the problem.
what he said^
and PLEASE.. PLEEEASE use some periods in your run on sentence... it makes reading really difficult.
it can be a multitude of problems but mainly due to worn out suspension components.
Worn steering rack bushings, control arm bushings, sway bar bushings
worn out tie rod (inner or/an outter) worn out LBJ, UCA BJ, end links... etc etc
if youre catching my drift.
Double check to see if everything is bolted down securely.
KickItOut
Suspension and Brakes
01-22-14 07:32 AM
