Front upper control arm
Old 05-09-12, 07:21 AM
SJ408sgmIS
SJ408sgmIS's Avatar
Post Front upper control arm
Besides the SPC ball joint to fix camber in the front. Does anyone make front upper control arms to correct camber? I'm about to lower my car but if I cant correct front camber, I wont be able to lower it
Old 05-09-12, 09:47 AM
projectdna
projectdna's Avatar
if you're running lowering springs, you won't need camber correction as much as you might think you do.
Old 05-09-12, 10:55 AM
SJ408sgmIS
SJ408sgmIS's Avatar
I'm going with coilover.
The 2is has been out for like 6 yrs now and I cant believe no one makes front adj upper control arms?
Old 05-09-12, 11:02 AM
projectdna
projectdna's Avatar
if you're worried about uneven wear on the tires ("camber wear"), best thing to do is to ZERO out the toe on your alignment and monitor wear semi-regularly.
if you were expecting huge aftermarket support for the 2is, consider this a reality check.
Old 05-09-12, 11:59 AM
SJ408sgmIS
SJ408sgmIS's Avatar
hahaha...Thanks for the reality check!
Old 05-09-12, 12:10 PM
jtsst
jtsst's Avatar
The 2IS actually has a caster problem if anything. Trying putting a larger wheel on the front and see how far the wheel pushes towards the front bumper.
Old 05-09-12, 02:28 PM
VIP LXS
VIP LXS's Avatar
I know of a company that make UCA and LCA for a 2IS, but is straight ballin type JDM shizznit... UCA is about $1200.00, and LCA nearly $1500.00 with caster/toe adjustment built in...
Old 05-10-12, 08:30 AM
SJ408sgmIS
SJ408sgmIS's Avatar
$1200.00 for UCA!!?? WOW!!! What is it made out of? "VIP LXS" you have a link where I can check those bad boys out?
Old 05-10-12, 11:17 AM
VIP LXS
VIP LXS's Avatar
I stand corrected, I just did the U.S. to Yen conversion rate, $1500.00 for the front UCA and $2500.00 for the front LCA. Im gonna keep the link under wrap because I want to be the first 2IS with these on. I had to do alot of research online and I had to ask my local shop that specializes in JDM suspension tuning for guidance. I'll give you a hint though, our car utilizes suspension components as the 3GS (i.e. front LCA/ UCA, rear LCA/ camber/ caster/ traction/ toe links.)
Old 05-10-12, 12:10 PM
Kurtz
Kurtz's Avatar
At those prices I don't think you need to worry about that too much
Old 05-10-12, 01:26 PM
CircuitMS
CircuitMS's Avatar
The Easiest and lest expensive route are the SPC camber joints, they work well and will give you some needed adjustment if you require it.
Old 05-10-12, 02:46 PM
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
4k + for some LCA. might as well buy a super charger
Old 05-10-12, 03:11 PM
kikaida
kikaida's Avatar
Here get these....
http://www.supernow.co.jp/shop/out.cgi?1+8
RC5
RC F (2015-present)
13
11-09-18 11:24 AM
Hyper15125
04-21-18 03:42 PM
ypkx
Suspension and Brakes
07-15-15 02:00 PM
azkaty
08-03-10 08:59 PM
92blacktt
17
03-16-09 07:37 PM
Quick Reply: Front upper control arm
