F-sport rear sway bar install
Hey everyone!
Just got my rear sway bar and tried to search to a step by step installation guide. I am very excited to put this on yet no clue. What tools do we need?
Here's the link to the instructions off of the Sewell website:
http://is.sewellparts.com/pdf/PTR0253094.pdf
Good luck. It's not that difficult if you follow the instructions.
Jack or lift the car up and you'll see exactly how easy it is. I felt the same way as you. Once I had the car on the lift and looked at it, I realized how ridiculously easy it was. All you have to do is remove the stock sway and put in the new one. Good luck!
Tis true.. however, the bolts are retardedly hard to remove....but given that its a safety reason.. i will rephrase.. the bolts are "not retardedly" hard to remove. Spray some PB Blaster on those bolts and let it soak for a couple hours. It will make your life much easier. =)
