ABS Light -> 1JZ Swap
I know this has been discussed before, but i haven't found an answer yet. Just a lot of ppl wondering how to fix the issue...including me
I have the ABS speed sensor (driftmotion) and know where it goes, but idk where to wire the signal wire to
Please help, that abs light is annoying!
Info On Swap/Car:
'96 SC300 5spd (Think it might have originally been auto)
Jza70 1JZ
Soarer Harness
Jza70 5spd ECU
Soarer/Chaser R154
https://www.clublexus.com/forums/sus...-1jz-swap.html
http://www.supramania.com/forums/sho...speed%20sensor
https://www.clublexus.com/forums/per...7-sc300-6.html
Info On Swap/Car:
Jza70 1JZ
Soarer Harness
Jza70 5spd ECU
Soarer/Chaser R154
i found a few posts that MIGHT be the solution...but nobody has confirmed if this is how to fix the issue. Can anyone confirm this??
https://www.clublexus.com/forums/4976673-post7.html
https://www.clublexus.com/forums/6954537-post9.html
https://www.clublexus.com/forums/6955166-post11.html
BigWaveSC
Performance & Maintenance
04-16-13 02:23 PM
kwbeach
Suspension and Brakes
07-23-12 06:45 AM
