So I dropped the back of the car yesterday
And now it has a reverse rake= front sits higher than the back why yesterday it was perfect and even what happened?
guess nobody knows what is going on with the car or why the front is raised
You must have lowered the rear a decent amount to be able to see that the front is raised. Just lower the front some more. It's because your front suspension is like a fixed height, so lowering the rear drastically will raise the front bumper. It's the same as lowering the front drastically, and you will see that the rear bumper is raised.
Do you understand?
Think of it like a bar that is horizontal to the ground with 2 legs. Lower 1 leg and the opposite end of the bar will raise
Charley
Do you understand?
Charley
did you drive the car around / jump up and down on the car yesterday before you saw that it was nice and even? suspension needs to settle every time you de-compress the springs completely (i.e. when you jack up the car). It probably settled itself overnight.
just so we're clear...
before "it was perfect and even" and then by your own admission you "dropped the back of the car" and you don't understand why the front was now higher than the rear?
brought back this thread because this how the car sits now plan to go lower
LexFather
Suspension and Brakes
17
08-10-06 05:55 PM
