will stock 97 supra springs and struts work on a 92 sc 400
Old 05-15-12, 08:08 PM
ChrisH
ChrisH's Avatar
Default will stock 97 supra springs and struts work on a 92 sc 400
Title says everything. Looking to get something like this http://toronto.kijiji.ca/c-cars-vehi...AdIdZ367202703
Old 05-15-12, 08:40 PM
ChrisH
ChrisH's Avatar
Bump. I've tried searching but I need a definite answer
Old 05-15-12, 09:21 PM
durps
durps's Avatar
yeah, and I am positive.
Proof. http://www.intellexual.net/faq.html#046
Old 05-15-12, 09:22 PM
durps
durps's Avatar
Taken from there
"Compatible Supra parts for the SC300/400
Supra wheels will fit the SC coupe perfectly; However, the offset is slightly less in Supra wheels (Lexus +50mm, Supra +38mm). This is not a substantial enough difference to create steering issues, but the wheels will look like they are tucked in by a little under an inch. This difference can be remedied with H&R 15mm spacers. Supra TT wheels are 17x8F and 17x9.5R, while the Supra NA wheels are 16x7.5. Both sizes are offered in chrome, polished aluminum, and silver finishes.
Any OEM and aftermarket suspension designed for the MKIV Toyota Supra will also work with the SC coupe. This includes all Supra coilover packages. Ony thing you must consider when shopping for Supra lowering spring packages: you must swap the entire strut-spring assembly from the Supra rear end, not just the springs. Meaning if you purchase Eibach Supra Prokits, you must also purchase Supra-compatible strut shocks, because the rear strut perch on the Supra sets lower than the rear strut perch on the SC. If you attempt a Lexus shock with a Supra spring, you will actually lift the rear end of the car higher than stock. The front struts are the same on both cars however. You have the option of buying the OEM Supra shocks (cheapest), or aftermarket Tokico, KYB, etc shocks. It is recommended that you replace all four shocks together for uniformity, instead of just the rears if you go this route. Supra NA and TT shocks will fit the SC300 and SC400 fine. You do not have to worry about these compatibility issues when you buy Supra coilovers.
Supra OEM front and rear sway bars will fit the SC coupes provided that you use the Supra sub-frame mounts - (info provided by Dave Martel). The stock Lexus sway bars have completely different sub-frames.
Supra OEM control arms can be interchanged with SC control arms."
Old 05-20-12, 10:04 PM
LEXXIUM
LEXXIUM's Avatar
Yes, those will fit!
Old 06-05-12, 02:12 PM
Durangosc
Durangosc's Avatar
another conformation that they will fit.
O. L. T.
SC- 1st Gen (1992-2000)
09-16-14 11:24 PM
scshinobi
599
08-07-11 07:49 AM
WillyD
Suspension and Brakes
12-02-10 10:02 PM
lexsc492
Performance & Maintenance
10-04-07 10:30 AM
mrshabo
04-27-04 07:05 PM
Quick Reply: will stock 97 supra springs and struts work on a 92 sc 400
