Brake noise
So I finally decided to install my coilovers. During the process, I also replaced the front lower balljoints and installed some roll center adapters. I also installed Figs mega arms and rear toe links. I got the alignment done and all was good. While driving the car afterwards I was feeling and listening for anything unusual. Then I hear this groaning noise coming from the front wheels. So I decided to check out front suspension/brakes, which is what I planned to do anyways to check if anything was loose after the install. I checked both the driver and passenger side. There were no nuts or bolts loose and there were no unusual scrape marks. I did find the passenger side rotor to not rotate freely. It seems to be not enough gap between the rotor and the inner brake pad. Other than this I have no other brake issues. The car brakes fine like before the work that I did. I have looked at the passenger side brake twice already and I did not see anything unusual. Do I need to be concerned? Or maybe the inner brake pad will eventually wear out some and there will be a bigger gap between it and the rotor? What do u guys think?
