Sourcing Brake lines for ABS removal
Old 05-21-12, 01:56 PM
OBEEWON
OBEEWON's Avatar
Default Sourcing Brake lines for ABS removal
So I've read every ABS removal thread. But no one listed any sources for these lines.
I'm looking to do this without converting to AN fittings so Jegs and Summit etc don't seem to have what I want. Also putting an in line Hydro.
Stricktly steel braided M10 x 1.0 lines and T's. Where did everyone get these?
Old 05-24-12, 05:22 PM
speed6
speed6's Avatar
The hard lines? At your local auto part supplier, IDK if the kids at autozone will know what you're talking about. I used to work at a AUTOVALUE / BUMPER TO BUMPER warehouse as a sales man, and we could get pretty much anything. (got my LS400 BBK +rotors and calipers there)
Old 05-25-12, 05:51 AM
Biggu
Biggu's Avatar
buy metal hard lines and convert them. Im pretty sure i listed all my part numbers in my build thread if you go back and read it.
Old 05-29-12, 08:21 AM
auk113
auk113's Avatar
look into MK4 supra ABS removal. there are write up
i'm sure these lines are colse if not same (did this on Trolls car)
Old 05-31-12, 06:46 PM
over40driv
over40driv's Avatar
This job is on my list of things to do.
Old 06-01-12, 07:34 AM
OBEEWON
OBEEWON's Avatar
Cool. Has anyone ever found the M10x1.0 T's? I will probably be doing it this weekend.
Aentony you should come by.
Old 06-04-12, 01:42 AM
Cleanshots
Cleanshots's Avatar
all you need is two hard lines.. and one tee.. i did mine and i have no idea why people make it more complicated than it seems..
right below where the steering shaft comes out of the fire wall, down by the frame there is a union there that goes to the back all you do is run a line to that for the back.
the other line just goes across and put a tee there and re-bend the other stock lines and attach it there; the three remaining lines all T together.
Old 06-04-12, 04:48 AM
OBEEWON
OBEEWON's Avatar
I was planning on doing one long single line to the back and teeing it near the rear to each wheel and then a T in the front in hopes that it would make my hydro more effective instead of two long lines to the back...if that makes sense.
Old 06-04-12, 05:32 PM
over40driv
over40driv's Avatar
Brake lines are slow going and make me a little nervous. Im assuming there wont be an official DIY on this so all pics are appreciated.
Old 06-18-12, 05:34 AM
OBEEWON
OBEEWON's Avatar
I'll post pictures when I do mine this week.
Old 06-30-12, 10:11 PM
chingpo05
chingpo05's Avatar
i just converted everything to A/N fittings and found T's that way. i bought everything at earlsfittings.com
Old 07-01-12, 10:27 AM
poorsupra
poorsupra's Avatar
go to the junkyard, MOST toyota corollas have the "T" grab em, go buy a hardline kit, and a flare tool. done and done, no need to buy expensive AN fittings or stainless lines. IMO hardlines are better if they are running the length of the car, BUT i did notice a stiffer pedal when braided lines were used at each corner replacing the rubber factory lines(hardline to caliper)
1.5jzsupra
Suspension and Brakes
02-16-10 12:04 AM
94_soarer
03-15-09 05:39 AM
margueritt
RX - 1st Gen (1999-2003)
05-13-08 03:17 AM
400DGRZ
04-04-07 04:41 PM
Epik
01-08-06 11:08 AM
Quick Reply: Sourcing Brake lines for ABS removal
