Squeaking brakes when cold?
Hey all,
I notice my break squeaking a lot when I'm rolling and trying to brake. This always happen when the brakes are cold. After they heat up, it gets better.
Is this a sign that I need new pads? I'm just wondering because I'm not sure if replacement is needed when they squeak with the brakes being either hot or cold.
Thanks!
Also... was there a TSB for this?
2010 IS 350!!
Thanks!
2010 IS 350!!
Yes.. there's a TSB out
Applicability
TSIB SUPERSESSION NOTICE
The information contained in this TSIB supersedes TSIB No. L-SB-0015-09.
^ Applicability has been updated to include applicable 2009 - 2011 model year GS and IS models.
^ The Repair Procedure has been updated. PLEASE READ ENTIRE TSIB.
TSIB No. L-SB-0015-09 is Obsolete and any printed versions should be discarded. Be sure to review the entire content of this service bulletin before proceeding.
Introduction
Some 2WD GS and IS vehicles may exhibit a squeal or squeak noise from the front of the vehicle when lightly applying the brakes. A new [...]
I was gonna go in BUT.. I found out they wanted to replace ALL my brake parts.So I decided not to go thru with it. Just go in if it's bothering you that much. It's covered as long as you're still under warranty (bumper to bumper)
Applicability
Introduction
Applicability
Introduction
Applicability
Introduction
Brakes - Front Brake Squeal/Squeak On Light Application L-SB-0011-11
I tried googling the actual document with no luck.. Any ideas where I can get a print out of this? I don't want to go to the dealer empty handed...
Thanks!
EDIT: I had no issue pulling up the older version of this TSIB, just not the newer one.
