Just installed F-Sport springs on 19" Got a question though.
I was just wondering, if these springs will settle down more? I heard that they will go down .2 inches once they have "Broken in". Just wondering because I hope I don't start rubbing once I go lower. I already have a minor rub on bumps and on full load.
Here's some pics:
If you seen these pictures already, sorry these are the only ones I have as of right now.
Thanks
![](http://img12.imageshack.us/img12/1154/dsc0143ub.jpg)
By keleis250 at 2012-05-28
![](http://img72.imageshack.us/img72/6752/dsc0186kc.jpg)
By keleis250 at 2012-05-27
![](http://img62.imageshack.us/img62/5479/dsc0150ia.jpg)
Here's some pics:
Thanks
Yeah, buts its not that bad actually. It doesn't make a mark on the tire of on the fender liner. Once It does though I will push it in.
despite it being a common myth, properly installed springs do not "settle"... they're solid metal, what could possibly be settling in the spring? Eibach even addresses this in their FAQ-
did you reset the bushings? If not they'll deform a bit which some folks will confuse as the springs settling.
How to do the bushings here:
https://www.clublexus.com/forums/5811432-post8.html
Originally Posted by Eibach
When Eibach suspension springs are fitted, will the car sit at the correct ride height or will it need time to settle?
All Eibach suspension coils are pre-set to eliminate settling and increase life expectancy.
I don't know. My stock IS suspension did settle. It went lower by it's own about .2 inches a few month after I bought it (brand new).....Spring usually settles and so do the rubber bushings. They have what we called cyclic load fatigue characteristic that, after a certain period of load cycles, they just deformed or compressed or distorted or whatever. And it will affect the vehicle ride height.
The springs can't.
Here's Lance telling folks the same thing-
https://www.clublexus.com/forums/4713653-post50.html
The lexus service manual says the same, as mentioned here:
https://www.clublexus.com/forums/3715907-post4.html
See also:
https://www.clublexus.com/forums/5126724-post21.html
or
https://www.clublexus.com/forums/5126746-post22.html
Here's Eaton who makes coil springs-
Originally Posted by Eaton
Correctly manufactured springs, both leaf and coil, are shot peened which removes stresses in the metal which occurs during the heat-treating process. The life of the spring is not only increased because of shot peening, the spring will not continue to take "a set" once it is installed.
http://www.howeverythingworks.org/page1.php?QNum=1438
Metals that bend only temporarily and return to their original shape when freed from stress are experiencing elastic deformation. Their sheets of atoms aren't sliding about and they can easily spring back to normal when the stresses go away. Naturally, springs are made from materials that experience only elastic deformation in normal circumstances. Hardened metals such as spring steel are designed and heat-treated so that the atomic sliding processes, known technically as "slip," are inhibited. When you bend them and let go, they bounce back to their original shapes.
http://curricula2.mit.edu/pivot/book...l?acode=0x0200
They even use a vehicle coil spring in one of their examples.
In short though a properly made coil spring should be elastic, and return to its original height, unless it's pushed beyond its limits (which it sure shouldn't be in anything resembling normal driving)
When you have the car in the air and don't have weight on the springs, then lower the car to put weight on them, you'll get a very small change.
But that change doesn't take long.
I mean like after a couple miles of driving (or just letting it sit on the weight for a few minutes).
After that the suspension height shouldn't be changing further due to springs "settling"
That's Hookes law... which governs steel springs...
http://en.wikipedia.org/wiki/Hooke%27s_law
Steel exhibits linear-elastic behavior in most engineering applications; Hooke's law is valid for it throughout its elastic range
You should only experience non-elastic deformation if you exceed the yield strength of the material.
Regarding elasticity-
A material is said to be ELASTIC if, when deformed by an applied force, it returns to its original shape when the force is removed. There are many familiar examples of this, such as a steel springs
RESILIENT materials are those that can absorb large stresses before they deform plastically. Coil springs are examples of this.
So while there is likely some range of physical stress you could subject a steel coil spring to that will cause plastic deformation, it should (on a quality spring) be well beyond the normal stress you would put on it in street driving.
hence the notion of "just drive it for a week or two to let it settle" is nonsensical... the only permanent change you would ever see would be if you pushed the spring well beyond its intended limits.
and if none of that is good enough I just quoted you directly from the people who make the F-sport springs (eibach) explaining they don't settle.
That's lowered on F-Sports? No way mine are much lower than yours in the front. I have 19's too and the fronts have almost no wheel gap and the rears looks the same. Did you reset/preload your bushings?
Shimozana
04-23-14 01:07 AM
EdwardK
Suspension and Brakes
03-31-11 09:11 AM
