KYb struts and Eibach springs
I really only want to lower it only 1" or so. I just got new 17 AR wheels and Michelin Pilot SS tires and i feel every bump i go over. I know a lexus should ride much better than mine does. I really like the ride of the l-tuned suspension.
I think im going to get BC or Megan LP's. Whats better?
thanks
Michael
thanks
Michael
thanks
Michael
thanks
Michael
Normally the Eibachs will give you that drop but with some Billstein shocks , but ultimately you'll end up paying as much as a set of coilovers. Make sure you do your homework when choosing a set of coilovers specially with Spring rates..
the BC with swift springs can be customized with different spring rates. Thats the problem, I have no idea what spring rate will drive like L-tuned shocks and springs. You guys talked me into coilovers from Eibach and KYB struts and im trying to learn everything i need to know but i need some help.
I just found out BC with swift springs and Stance are the same price? Now what? Im so confused!!!!!!
Michael
Michael
Okay, I'm new to this and yes I have done research. Everyone seems to like or prefer springs with a non stock strut/shock combo. I was reading about the specs of the eibach prokit and it says something like "springs are compatible with oem shock/struts or replacement shock/struts". My question is, I was thinking about getting eibach and brand new shock/struts from Sewell. Will this work or is it a waste of money since these are stock and it will not support the 1" drop. My car is all stock right now, I plan on keeping the stock chrome (16"), but I don't want the wheel/fender gap anymore.
