Coilovers on for a day and VSC/ABS goes off?
Old 06-18-12, 03:57 AM
SSxblazer
SSxblazer's Avatar
Default Coilovers on for a day and VSC/ABS goes off?
Anyone have this as an issue? Just road around to the alignment shop and after they were done the VSC and ABS lights came on a mile down the road.
Did not have time to take it back, but curious if anyone else has experienced this? Also, the speedometer went out.
thanks
Old 06-18-12, 05:01 AM
BiGEZ
BiGEZ's Avatar
Sound like a sensor got knocked out of place. I would check the sensors first.
Old 06-18-12, 05:35 AM
SSxblazer
SSxblazer's Avatar
TY For a swift response!
I am taking it to the shop today anyway due to the tires rubbing on the fender well (will have to raise the rear 1/4th inch or so). So I will have them check it.
Thanks again!
Old 06-18-12, 06:27 AM
99 GS3
99 GS3's Avatar
Yup they broke an abs sensor/wire... Speedo reads from the wheels not the trans like most cars.
After you repair/replace the broke sensor you may still need to do the tc/e1 diag dlc procedure if a battery reset doesn't clear it.
Old 06-18-12, 07:44 AM
neegroy
neegroy's Avatar
i remember i had the same problem but it wasnt after i installed my coils. it happened when i drove through a HUGE *SS CRATER! it was bad, but the next day all the lights went off. phew...
Old 06-18-12, 09:21 PM
try2fndmrk
try2fndmrk's Avatar
ABS/Wheel speed sensor got tampered with. Still needa replace mines!
Old 07-17-12, 03:27 PM
GS671
GS671's Avatar
So what was the cause of the lights to go on?
I'd rather have my engine knock than to have those VSC lights go on!
Old 07-18-12, 07:37 PM
geeznuts
geeznuts's Avatar
Engine knock: replace motor
VSC light on: replace a sensor by the wheel
I'll take the light over the knock lol
Old 07-18-12, 11:21 PM
vwynn
vwynn's Avatar
you prolly messed up the abs line... if its cut u can resolder.. if its messedup where u cant fix then u gotta replace.
its a easy fix but yea just annoying
Old 10-10-12, 11:31 AM
YxUxMADDDD
YxUxMADDDD's Avatar
My lights came on after I switched from bags to stance coilovers. My coilovers didn't come with brackets so I zip tied the brake lines to the struts. Abs/vsc came on. Now, abs/vsc/vsc off lights are on....
frankiejay
09-12-18 04:35 AM
1NICESC430
08-20-18 01:16 PM
is350og
Suspension and Brakes
06-12-11 05:25 AM
systemover
10-31-08 02:22 PM
blkgs4wnav
05-31-07 06:29 AM
Quick Reply: Coilovers on for a day and VSC/ABS goes off?
