Original Brakes Lasted How Long?
I've seen folks claim they "needed" to replace their brakes at 15-20k miles... and others with well over 50,000 and plenty of life left.
I've got a 350 myself, original rotors, low dust pads put on around 7k miles, and based on current rate of wear I expect to get roughly 60,000 miles out of them before they're at min spec.
My brakes are at 72k without being changed. I would have thought the front brakes would have been changed when I bought the car (CPO) but apparently they had plenty of pad left. Previous owner did EVERYTHING at the dealer (Even wipers and balancing wheels) and I see no record of brakes being changed previously.
IS350, I just changed my rear pads myself at 46k, mind you this was after I tracked the car for 2 days at a Drivers Edge event. I do try to minimize braking in my daily driving. My fronts are still 50% because I used the low dust TSB after I tracked. I tracked the car around 7500 miles. So the fronts have close to 40k on them and still 50% or so
I made it to 60K miles on my pads, had the low-dust TSIB done at 15K.
Still on my original rotors. They should last until ~75K based on the rate they seem to be wearing. (Though maybe more, because I'm not sure if the dealer re-surfaced the rotors when they did the TSIB. I'll have to check my records.)
