Coilover help suggestions...JIC Magic vs. HKS Hypermax 2 vs. Cusco Vs. Toms Advox
Im currently running Tein CS coilovers and im trying to switch it up to something that goes lower and is stiffer, i was wondering if anyone can help guide me in the right direction, ive been doing some research but im still not sure of which one i want to go with because i couldnt seem to find out the ride height adjustability on them, I definitely want them to go lower than my Tein, i pretty much want to slam it but also have a tight stiff ride, here are the ones i have to choose from:
JIC Magic, HKS Hypermax 2, Cusco, and Toms Advox
JIC would definitely do the stiff part for ya. Cusco is also decently stiff but not as badly overdampened as the JICs. Cusco's are my favorite off the shelf track setup.They could use slightly more spring but the Showa dampener is fantastic for an off the shelf piece. HKS is a good setup that compromises between street and track use best of the options you mentioned. I have no experience with Toms.
Can't comment on "slamming." Not my thing
Cool thanks Man, which one would you say is most durable and I may not slam the car right away I just would like a coilover that if I ever wanted to it would be possible to do. The Teins I have are basically maxed out and still doesn't seem low enough, well the front is fine but the back sits too high, my top two choices were either the Jics or Hks, I was thinking Cusco as an option too but i imagine it would be hard to find a place to rebuild them if needed
I can't comment on longevity but both are reputable brands. All 3 are probably the same difficulty with rebuild/revalve. Meaning, none are easy to get rebuilt but there are places that will do it. JIC would be the toughest because IIRC they need to be sent overseas (a Z buddy of mine had years back)
thanks for your help, all of the coilovers i've found were basically around the same price so it was kind of a tough decision, but from the sounds of it i should go with the HKS hypermax, i just mainly want something street/track, that can also handle these bumpy roads down here without being a PITA to drive, that will also adjust lower than the TEIN CS
Update: I finally got the HKS on but something doesnt seem right the backs are able to adjust really low but even on the stiffest setting they still feel soft, the fronts are adjusted low as it can go and still has an inch of wheel gap but it rides pretty good and feels stiffer than the backs even on the softest setting, as of right now the back is sitting lower than the front even with the back having a lot of adjustment left, I was wondering if because of how it's sitting is it possibly transferred most of the weight to the rear causing it to feel like this
I recommend Tein Flex if there's "Daily driving" involved, since - unless it's a track only car - you'll be driving on normal roads (speed bumps, potholes, driveway dips, etc.) a LOT more than on the track.
The CS don't go low at all compared to the Flex. Combine that with EDFC and it's a sweet setup. I've had mine on for almost 6 years now, brought them in for a rebuild a couple months ago and they said all I needed to do is wipe the road dust off, because they were fine (no leaks, no maintenance required).
hey, i saw a bunch of you guys saying you like the cuscos.
can you tell me what are the options for cuscos. from what ive seen, you can get them with or without adjustable dampening. do they all come with independent ride height and preload?
heres a picture of the ones im talking about
thanks
scott
thanks
scott
