Relocate Wirring Harness if dropped on MKIV TT Springs
Hey guys this might be an thread dicussed awhile ago but I really didn't find anything. If you lower an SC on MKIV TT Lowering Springs/Struts do you really need to relocate the wirring harness? When settled it should be about 2" lower correct I remeber on my solara I was about that and I had no problem w/fender rub what so ever. I have a couple of friends who lowered their SC's on TT setup and have NOT relocated the wirring harness and haven't had any problems. I would just like some opinions/concerns/etc. My wheels are 18X8 +38 tire size 245/40/18 if that helps.
Thanks
-Nick
Thanks
-Nick
Not needed. You are effectively riding on a OEM wheel diameter. (your 245/40/18 is the same as the stock 225/55/16) The TT front springs only lower by 1", not 2". And anyway, the TT spring rate is much higher so the wheel travel will be less on rebound.
You're fine.
You're fine.
