spring compressors for coilover install?
i was wondering if I can get away with not using spring compressors to get the old struts out to install my coilovers. I've read through a few howto's and they say they will be needed but I'd like to hear other peoples experience's
You don't need them to remove a factory shock/spring setup or install a pre-assembled and preloaded of-the-shelf coil over. You do need to rent a spring compressor in order to reuse your OEM top hat for an assemble-it-yourself coil over setup like the Gixxer_Drew or similar coil over-- or a regular shock and spring upgrade.
assembled, coil, coilover, coilovers, compressor, definition, gs460, install, installation, installing, intall, lexus, overs, pre, spring
