Car Is hydro Planing on dry roads
Old 07-05-12, 01:37 AM
yaaayouuu
yaaayouuu's Avatar
Default Car Is hydro Planing on dry roads
98 gs400 all stock with 180k miles. Service unknown, just got car last week. Abs, vsc, vsc off lights on. When I drive the car in dry conditions and hit a bump in the road the car wonders or hydroplanes for a second. But tonight it rained and it got scary where at one moment I had no control and the car was serving side to side and I had to fight it to stay in the lane. Soon down the road a mile from my house the Check engine light came on. Does anyone know what could be the problem? I have work tomorrow and got to drive 80 miles round trip and don't want to be stuck on side of road.
I'm going to take off battery n reset ecu to see if that clears the check light.
Any thoughts? Caster arm bushings? Lower bj? Maybe worse?
Thanks
Old 07-05-12, 02:20 AM
Dawa
Dawa's Avatar
lol what? i thought you were trolling for a second.
whats your tire pressure at
Old 07-05-12, 02:24 AM
abounly
abounly's Avatar
alignment.
Old 07-05-12, 09:10 AM
GSteg
GSteg's Avatar
I'm assuming you're not driving around on worn out tires..
Old 07-05-12, 09:25 AM
repugnante
repugnante's Avatar
^ I'm certain he his....
Get new tires...
Old 07-05-12, 10:08 AM
yaaayouuu
yaaayouuu's Avatar
The tires have 90% tread left and I don't see how tires would cause my check engine light to turn on soon after the incident. I mean it's pretty darn scary driving the car when it s wet. Lol
Old 07-05-12, 11:10 AM
Dawa
Dawa's Avatar
it sounds like 2 separate, unrelated problems that you have to troubleshoot individually. always start at the absolute bottom of the ladder. get rid of the basic, inexpensive possibilities first. since you just got the car i would suggest an alignment too since its new to you. unless you plan on lowering it or greatly changing wheel/tire size soon,
Old 07-05-12, 02:01 PM
99 GS3
99 GS3's Avatar
If the car has a 180k on it and doesn't have new tie rods inners/outters, caster arms, rack bushings, and ball joints then it can defiantly cause wandering and pulling, of course check the obvious alignment, tires, lug torque, and centerbore seating flat.
My car wandered some on bumps when it had worn out caster arms.
Old 07-05-12, 02:07 PM
77i9
77i9's Avatar
ok just to clarify, you cannot hydroplane on dry road. Hydroplaning means the tires are riding on top of the water. I think what you meant to say is fish-tailing, i.e. the rear end swings from side to side. You would have to describe the symptoms with a little bit more detail. For instance when you said you hit a bump, how fast were you going and how big or small was the said bump.
I have had this happen to me on my 91 accord. The rear shocks were worn out and when I hit bumps/pot holes are fairly high speed even on dry roads, the rear of the car would wander. But since the accord is a front wheel drive it wasn't such drastic fish-tail. Now, since the 2GS is a rear wheel drive car this will be more pronounced.
Old 07-05-12, 03:37 PM
yaaayouuu
yaaayouuu's Avatar
Ok at low speed or high speed the car will wander. Big bump or small bump on the road will cause it when dry. When wet with no bumps following cars in front of me in their tire path the car will just suddenly start to sway back and forth drastically.
Shocks are seemed to good from doing a bounce test and checking for leaks and what not.
Also did a small check by turning the wheels to see hear pop or crackle like the lower bj thread said.
Heard nothing.
Re tighten lugs and made sure they seated well.
Didn't check the caster bushings and tie rods looks good as I tested by jacking up the car and shaking wheel side to side and up and down for play.
It's getting to the point where it's unsafe for my pregnant wife to drive or even ride in. Since its our only vehicle ATM its gonna be hard until I can figure out whats wrong with out
Just throwing money at random parts to see if that did it. Lol
Old 07-05-12, 04:45 PM
MrG4Life
MrG4Life's Avatar
I have to admit when I saw the thread title I chuckled and had to take a look at this thread. OP, your car cannot hydroplane on dry pavement. A '98 GS with 180K miles warrants a thorough inspection of the front end suspension and steering components. Getting an alignment is a waste until you first check out those parts and replace if necessary. As for the CEL, check that out to see what the code is.
Old 07-06-12, 03:00 AM
VIPatrick
VIPatrick's Avatar
Had the same problem with low tire pressure and a bad alignment on the rear.
I sometimes wonder how the guys with tucked wheels and 2 digit camber can drive faster than 35mph.
Old 07-06-12, 03:56 AM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
I think you meant tramlining
Old 07-06-12, 10:55 AM
GS4_Fiend
GS4_Fiend's Avatar
Get ur alignment checked out. With an alignment specs, you can determine whats wrong
Old 07-06-12, 12:23 PM
PHML
Master Thread Closer!!
PHML's Avatar
Try checking your sway bar and sway bar end-links.
Quick Reply: Car Is hydro Planing on dry roads
