Help! Destroyed tires - IS250 AWD on F-Sport Combo
Old 07-15-12, 11:44 AM
richf
richf's Avatar
I had Dunlop Sports and now have Contintental DWS - so no.
Old 07-15-12, 01:06 PM
Sango
Sango's Avatar
Could be the tire is heaver. No summer tires? Generally A/S is heavier if I am correct.
The alignment can affect it as well.
Old 07-15-12, 01:16 PM
richf
richf's Avatar
No, I've been running A/S since I got it, I didnt want to deal with 2 separate sets in winter.
18 mpg is dysmal and pissing me off. I hope it gets fixed after the euro tire alignment.
Old 07-15-12, 01:20 PM
Sango
Sango's Avatar
You get better MPG and better stopping distance with dedicated tire sets.
Could you verify your exact tire model for your Dunlop and Continental?
I had a quick look of tires but wasn't sure exactly which ones and I made some quick assumptions which I think you have. I have a hunch that the DWS is a heavier tire than your previous based on the model I looked at because it does have a tire tread life rating, so there are some trade-offs.
Old 07-15-12, 01:45 PM
richf
richf's Avatar
Dunlop Sport 5000 M and Continental ExtremeContact DWS(Ultra High Performance All-Season)
Old 07-15-12, 02:10 PM
Sango
Sango's Avatar
I see. The higher tread life rating would usually use a bit more MPG to get the better tread life. 300 to 500+ in comparison.
Old 07-15-12, 03:33 PM
clubfoot
clubfoot's Avatar
Don't take this the wrong way, but you live in NJ and you want to use all-seasons for winter?!! Are you crazy? Yea, last winter was mild, but dedicated winter tires are the only way to go.
Old 07-15-12, 03:34 PM
richf
richf's Avatar
Last few winters have been pretty mild. :P
Old 07-16-12, 06:03 AM
Toymota
Toymota's Avatar
That's weird. It normally wears like that only on the fronts. Did you rotate your tires and have the rear tires at the front at any time?
Old 07-16-12, 08:59 AM
richf
richf's Avatar
Just spoke to euro tire - they said the alignment was good. Hmmmm.... Guess I'll have to keep a close eye and rotate religiously.
Old 07-16-12, 09:29 AM
Sango
Sango's Avatar
Good with even out of spec? No way.... That's definitely does not sound rite.
I know I had another member go to the shop alignment shop I go to with their AWD + F-Sport shocks, and all is in spec.
Old 07-16-12, 09:31 AM
richf
richf's Avatar
Could you get me that alignment sheet and I could send it over to them?
Old 07-16-12, 12:18 PM
Sango
Sango's Avatar
I'll ask, the member has not not been online in a while.
Old 07-23-12, 05:36 AM
Toymota
Toymota's Avatar
You should check out this IS-F thread: https://www.clublexus.com/forums/is-...eo-inside.html
Basically it says the bushings are too soft so the front tires dynamically toe out when braking causing the inside tire wear.
Old 07-27-12, 11:08 AM
oem
oem's Avatar
alginment report may have not been consistent with final adjustments they have made after the report was printed.
Quick Reply: Help! Destroyed tires - IS250 AWD on F-Sport Combo
