Bad vibration at 65mph(It's not the balance)
UPDATE:Aug 27-replaced the differential,opened up the old one to find a few of the spider gears are ate up.Overall the "main"noise and tramlining are mostly gone but,now I have this little tingy-ting ting noise still coming from the rear?Ideas?
UPDATE: Aug14.we got it on a lift and found out that the diffrential bearing is gone.It's on the driver side there is quite a bit of play from the CV and diff
now I have to source a used diff since ....thanks anyways guys for the input
Car is a 93 SC300 5 spd 130k miles.Started about 4 months ago and progressively has gotten worse but,the rear passenger side has a very bad vibration which starts at 65mph and peaks at 70mph.Best way to describe it is a very bad off balance/heavy vibration coming from the rear passenger.The wheels are staggered 18's they have all been balanced twice(different places)in the last four months.My fathers an engineer and thinks it might be coming from the drive shaft but,I'm lost at what it might be.I checked for loose bolts,diagnosing bad bearings etc.There's no vibration in the steering wheel just the car itself.Anyone?
Thanks for reading.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Thanks for reading.
Read this, very helpful. It diagnosis almost every vibration issue and where to look.
http://www.twinturbo.net/nissan/300z...ibrations.html
yeah, check your drive shaft first, then check your rear passenger side upper control arm, It's probably the control arm bushing gone, just went thru the same problem. my rear pass upper control arm bushing was gone, redoing the whole car soon as the parts come in, needed it anyway since my car has over 310k in miles with original engine tranny everything still oem. good luck
stevek57
08-21-17 12:51 PM
