Need a quick confirmation about SPC ball joint installation
Old 08-20-13, 09:32 AM
e46m3lol
e46m3lol's Avatar
I'm about to get these SPC ball joints installed on my IS250 but I heard from someone that I will not be able to have my car slammed as the upper control arm will hit the top portion of the wheel well...
Can anyone confirm this?
Old 08-20-13, 10:26 AM
projectdna
projectdna's Avatar
^ I've read/heard the same.
Old 08-20-13, 10:30 AM
Jump2man3
Jump2man3's Avatar
I have the spc ball joints. Im not totally slammed. But flush no issues. My guy said I could probably go lower 1/2 3/4 with still no issues
Old 08-20-13, 11:24 AM
Gville350
Gville350's Avatar
I'm lowered to a tad less than 24" fender-to-ground...aka slammed. I ONLY hit the UCA against the upper wheel well on huge potholes or bumps. If you're afraid of damaging the ball joint due to this...don't be. The SPC ball joint is SAFER than the OEM ball joint in these cases, as the OEM unit is just pressed into the UCA and can/will pop out on BAD bumps (happened to me!). The SPC is afixed to either side the UCA, so it'll not pop out.
If you find yourself to the point where you're hitting the UCA against the upper wheel well too often for your liking, you can always do this :
Old 08-20-13, 04:07 PM
e46m3lol
e46m3lol's Avatar
I really appreciate the info. I'm currently sitting on 18" wheels at around 24" from the ground to the center lip of the fenders. Now that I got my worries out of the way... I'll proceed to installing them.
Old 08-20-13, 05:35 PM
Gville350
Gville350's Avatar
^Same here! 18" stockers, but I've got 35 series tires now. So it's even lower! LOL
Old 01-19-14, 09:05 AM
bboysunone
bboysunone's Avatar
Gvilleis250 ...what did u exactly do . Cut a hole under the hood rite above the uca?? I just installed spc balljoint last week. N over some bumps/pot hole on 40mph It seem like hitting some parts kind of loud n I don't like the sound of it.
Old 01-19-14, 09:34 AM
Gville350
Gville350's Avatar
^I didn't cut a hole, I grabbed that picture of the net from another Lexus model vehicle. You need to confirm that it is indeed the top of the SPC nut hitting the underside of the fender-area; it could be a loose nut/bolt or the ball joint not seated fully into the UCA.
GL!
Old 01-19-14, 07:23 PM
bboysunone
bboysunone's Avatar
GL!
Thanks anyaway. Illl guess I take a look under the car this week sometime n see whats rreallygoing on. Btw I m drop on bcr coilover fender to ground 23.5 inches with stock 18s.
Old 01-20-14, 12:11 PM
Gville350
Gville350's Avatar
^Yeah, I can see you'd be banging then. What rim/tire combo are you running? I'm on stockers still, but running 35 series sidwall BFG KDWs. ~24" fender to ground.
Old 01-20-14, 12:47 PM
e46m3lol
e46m3lol's Avatar
Gville... you're everywhere! ha ha
I've been having this issue ever since I installed the SPC camber ball joints. I'm at 23" from the floor to the top portion of the fender. I got used to the thumping noise whenever I hit a dip or a bump in the road. I was thinking about cutting a hole where it hits. Has anyone had any issues after they cut it?
Old 01-21-14, 12:45 PM
Gville350
Gville350's Avatar
^i don't think I've read about any 2IS owners having actually drilled the hole yet in there shock tower. Just don't cut it any bigger than it needs to be. I'm sure it'll be structurally fine.
Old 01-31-14, 07:09 PM
bboysunone
bboysunone's Avatar
I m on stock wheels 225 40 18 up front and 255 40 18 in rear.michellin super sport as tires. I m thinking to raise my car up half inch. To 24" from fender to ground.
UGJZZ31
Suspension and Brakes
10-31-12 04:13 PM
twenty
05-30-11 12:14 PM
t70 supra
SC- 1st Gen (1992-2000)
01-18-11 08:50 PM
lunatyk
18
08-22-10 04:14 PM
Quick Reply: Need a quick confirmation about SPC ball joint installation
