Old 12-16-14, 11:57 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
Print Wikipost
brake pedal randomly goes to floor?
Old 08-19-12, 05:07 PM
89supra884
89supra884's Avatar
Default brake pedal randomly goes to floor?
well all my fluids are good and no leaks. but randomly when i drive the brake pedal goes to the floor. when i pull off of it and pump its ok. anyone had this problem?
Old 08-19-12, 05:43 PM
2JTsc300
2JTsc300's Avatar
are your rotors warped?
Old 08-19-12, 05:47 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,257 Likes on 1,371 Posts
Have you changed your brake fluid lately or work on your brake system? Did you bleed your brakes?
Old 08-19-12, 06:06 PM
OG Dada
OG Dada's Avatar
Gotta bleed your brakes and more likely flush the system if it's dirty....
Old 08-19-12, 10:41 PM
Blkexcoupe
Blkexcoupe's Avatar
If your brake pedal is dropping to the floor your master cylinder could be going bad.
Old 08-19-12, 11:19 PM
OG Dada
OG Dada's Avatar
^^^Not necessarily, but can be one of the reasons, or the brake booster hoses are busted or have leaks.
Old 08-20-12, 05:48 PM
89supra884
89supra884's Avatar
ill deffiently try to bleed/flush the system. i have not done any work yet. i bought it 2 weeks ago and just trying to work out the kinks
Old 10-03-12, 09:43 PM
phatbear79
phatbear79's Avatar
im having the same problem. it looks like the master cylinder along with warped brake lines could be the culprit..
Old 10-04-12, 08:50 PM
SEXC
SEXC's Avatar
I recommend doing the brake flush first since it's cheaper and odds are it hasn't been performed in a while.
Old 10-05-12, 02:32 PM
V8drummer
V8drummer's Avatar
I had the same thing happen to my old Chevy truck, it was the master cylinder going bad. Make sure and get it checked out soon!
SorrGwa
Suspension and Brakes
39
05-08-17 04:00 AM
Lexus082
06-21-11 05:39 PM
Avarec
SC- 1st Gen (1992-2000)
04-14-10 02:27 AM
gcam77
02-06-08 08:53 PM
jimbo22s
07-26-04 07:04 PM
Quick Reply: brake pedal randomly goes to floor?
