Squeaky Suspension Question.....
i have an 06.......and since last week when i go over speed bumps or any type of bump for that matter........including turns.......there are small creeky noises and sounds as if bushings are dried out. On the is250's i know that some bushings are replacable and some are not. Has anyone else had these noises before and if so, how did you fix it...................on a budget.
i have stock suspension. Its coming from the front of the car. At first it was just light, but now its become increasingly louder...........and annoying. The tech at Lexus over the phone, without seeing the car, believes it is the say bar bushings........taking it in today
Just an update for you guys. Got the car back and its fixed. It was a shock mount bolt on the drivers side that was loose. So before you invest in bushings and all that. Just take it in have them do an overview of you suspension and all the bolts and mounts, mot likely you have a loose one in there that needs tightening. Hope this helps.
Deegee
Suspension and Brakes
08-22-15 04:24 AM
