LS400 VS Supra TT Calipers
Old 08-25-12, 12:30 AM
818GS
818GS's Avatar
Default LS400 VS Supra TT Calipers
Which one helps you stop sooner?
By the way I did search but I got a lot of mixed results and just a bunch of numbers.
Thanks in advance.
Old 08-25-12, 02:15 AM
abounly
abounly's Avatar
Supra, they have more pad variety. Should really stop making threads.
Old 08-25-12, 05:35 AM
Lexusfam
Lexusfam's Avatar
Supra is better imo because no RCA is needed and better pad/rotor selection, but harder to find. I got all the info I needed by searching btw. There is a ton of info on this. I even have my wheels picked out and my is350 wheels for spare. Just waiting for the calipers to pop up.
Old 08-25-12, 06:04 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,258 Likes on 1,371 Posts
Neither will help you stop sooner than your oem brakes which are a great system. What they WILL do is give you better pedal feel, better resistance to fading from heat (not usually an issue unless you are doing a track event on a road course) and will look cooler.
Imo you can get 75 pct of the above with upgraded ss lines, some quality synthetic high temp fluid like motul or ate, some more aggressive pads and caliper paint.
Old 08-25-12, 06:58 AM
Rock-a-Lex
Rock-a-Lex's Avatar
^ I agree with Dave and that's exactly what I did. If I would ever upgrade, it would be to a BBK. Only because you would probably wind up spending $400 - $700 anyway on the above setups. May as well put this towards a front BBK like Wilwood, Rotora or StopTech which you would probably spend $1200 or so on. GL!
Old 08-25-12, 09:59 AM
Lazy
Lazy's Avatar
Get good tires..
supraguy2
03-06-12 11:06 AM
shivan0124
Suspension and Brakes
02-28-12 10:53 PM
YeA 2jZ
SC400 / 300 Classifieds
11-25-10 06:05 AM
Lextreme
20
04-28-10 02:37 PM
Quick Reply: LS400 VS Supra TT Calipers
