front or rear? Front SPC ball joints ONLY if you're not planning on going too low, rear has Megan camber arms(most commonly used) and then Figs(baller status)
i went back to stock wheels, with a tein drop. What do you think do I need the Figs or Megan camber kit will do the trick? and also i need to change my rear shocks, do you think i should do new shocks from lexus or should i do the tokiko blues in the rear? and should i change all four? or just the ones in the rear and keep the front same with the stock shocks? thanks for the advice
do you think lexus is350 with f sport srpings and shocks need a camber kit? to get alignment?
You won't need a camber kit. I run this type of setup and the drop isn't drastic to where it can't be adjusted without aftermarket kits. But an alignment is a must since you are lowering it about .7 inches.
