Have Negative Camber Front + Rear Helpp
★ I
Hey guys i need to fix my negative camber on my front and rear, my accentrick bolts are frozen on my rears so im pretty sure thats maxed out. What would i need to fix this?
Thanks
Thanks
Front:
-: SPC UCA's
-: Raise the car
Rear:
-: Battle Version RLCA's
-: Battle Version RUCA's
-: FIGS RLCA's
-: SPC Camber Bolt
That's pretty much everything that's available to fix camber or add more camber. I think rear RCA's lower the rear about an inch though and save about 1 degree of camber, so that could be an option for the rear also.
-: SPC UCA's
-: Raise the car
Rear:
-: FIGS RLCA's
-: SPC Camber Bolt
Master Thread Closer!!
If you want to run either the SPC rear or SAGE/Exact rear RCA kit, you must be able to remove the stock eccentric bolt.
Good luck.
Pete
