Suspension arms.
Old 10-14-12, 09:17 AM
Candela
Candela's Avatar
Originally Posted by dat_flip
Why did you have the lower arms shortened?
Since the car was so low, the arms were shortened in order to bring camber angle degrees closer to neutral
Old 10-15-12, 12:09 PM
vietunit
vietunit's Avatar
Originally Posted by ArodDaLob
stance coils w/ swift springs
battle version subframe bushings, toe rods, traction rods
tc sportline ruca
stock rlcas that were shortened by battle version. bushings were changed out to prothane.
My fronts are stock arms with prothane bushings
Daizen swaybars f/r with ****ty custom endlinks
do want
Old 10-15-12, 05:29 PM
V8drummer
V8drummer's Avatar
Does anyone know if it's possible to use rear Supra LCA's on our cars? I know the Supra arm is supposed to be shorter, but wouldn't that help correct excessive negative camber for lowered people?
Old 10-16-12, 12:11 AM
ArodDaLob
ArodDaLob's Avatar
Originally Posted by Midengtoy
^^^ Wow that is an amazing picture. So after all the does the car handle better? I always imagined these cars being heavy boats and no matter what's done they'll still handle like crap.
it's better than stock, which was the goal i was looking for in the beginning. then it kinda rolled out of control. Was all the time investment worth it? hell yes.
Originally Posted by xspsi6
They are^^ It will never handle like an evo I love these cars but handling is not their strong point.
That's why i went straight for the suspension on this car. the lower the standards, the easier they are to surpass.
Originally Posted by vietunit
do want
get.
Candela above pretty much answered it. I've raised my car since about an inch or 1.5" and the rears look dangeously close to having positive camber, but I still have a ton of adjustment so that won't be a problem in the least.
I thought supra front and rear lca's were the same length as sc's
Old 10-16-12, 02:33 AM
V8drummer
V8drummer's Avatar
The fronts are a given for sure, but not sure about the rears. I just read it a few times on the forum that the rears may be shorter
I've never read of anyone using a Supra rear lca though.
Old 10-16-12, 07:11 AM
Candela
Candela's Avatar
I assume they're all the same length, I make that assumption because when you look at aftermarket arms it usually says JZZ30/JZA80
Old 10-16-12, 10:39 AM
BattleVer
BattleVer's Avatar
The supra rlca is a different length then the sc. So are the toe links. Both about 2 in shorter.
I tried to measure it up to see if they would help correct the rear camber but they are way off in length from the originals.
Jockey
Suspension and Brakes
11-03-14 11:57 PM
Quick Reply: Suspension arms.
