Parts.com - caster arms
Old 10-05-12, 01:48 PM
baconcake
baconcake's Avatar
Default Parts.com - caster arms
Are these two parts, called rear lower arms, part #'s 4866030281 and 4867030281 the proper OEM caster arms with bushings installed? They are priced at $114.03 and would be a great deal if they are legit. Anyone know if they are true arm with bushing installed?
heres the link to the website with the two arms in the cart: http://www.parts.com/parts/2003/LEXU...iagram=8909225
Old 10-08-12, 08:01 PM
GS714
GS714's Avatar
Default The #8 on diagram
The #8 on the diagram is the caster. tension rod or Lower Control Arm #1. Just print the diagram and take it to your local dealer. The price difference is not that dramatic. The most important component beside the caster is the Lower Ball Joint. It is best to replace them at the same time.
http://www.carsontuned.com/index.php?id=10
Old 10-09-12, 05:13 AM
lexusben
lexusben's Avatar
Buy the arms from Sewell (http://lexus.sewellparts.com/oem-cat...S400-1998.html).
They are $120 a piece with the CL Discount.
I believe part numbers 4866030281 and 4867030281 are the 01+ arms and then
4866030240 and 4867030240 are the 98-00 arms (more expensive oddly enough).
You can also get the set here: http://lexus.sewellparts.com/accesso...1998/2951.html which I believe contains the 2001-2005 arms.
Old 10-09-12, 08:04 AM
baconcake
baconcake's Avatar
thanks for the replies. I ended up buying the caster arms from sewell and getting MOOG lower ball joints and outer tie rods from ebay. Going to install them when they arrive in a few days.
riknchar
02-25-20 06:48 PM
shurian
Suspension and Brakes
77
03-31-15 05:58 PM
downrigger
12-05-13 10:59 AM
questnyc
05-05-08 06:42 PM
itazura
03-07-08 11:40 AM
Quick Reply: Parts.com - caster arms
