Rear Camber Adj. Bolt Location
Old 10-12-12, 02:47 PM
SprtDesign
SprtDesign's Avatar
Default Rear Camber Adj. Bolt Location
Trying to add a little more negative camber to clear my rear fenders. Which one of these are the adj. points for the rear camber (GS300).
Thanks.
Old 10-13-12, 01:23 AM
PHML
Master Thread Closer!!
PHML's Avatar
Pic #1 is for camber....Pic #2 is for Toe.
Old 10-13-12, 05:29 PM
TimWalker
TimWalker's Avatar
if i were to adjust the camber eccentric bolt wouldnt the toe need to be adjusted too? since the lower arm is slightly to the rear it seams that you couldnt only adjust the camber but would have to adjust camber and toe at the same time
EffSport
Suspension and Brakes
23
02-13-15 08:41 PM
Sheehan1p
09-05-12 03:57 PM
FinLIFE
08-03-11 08:58 AM
menty
09-06-09 06:19 PM
buffalosoj
02-09-09 10:27 AM
Quick Reply: Rear Camber Adj. Bolt Location
