OEM Low Dust Pads
OEM Low Dust Pads
Need comments from current user.
Does dust really decrease?
How is the initial bite and overall feel?
Is it aggressive on the rotor?
Thank you guys in advance for your kind comments.
10th Gear
Way less dust.
Overall feel pretty much the same, maybe without the initial soft pedal feel, stiffer feel in my opinion or my imagination. Do not notice any braking power difference.
No aggressive wear on my rotors.
I definitely recommend using the low dust pads. I will be replacing my second set of low dust pads during my snow tires change soon.
BTW, mine is a 2008 IS350. Not sure if this is a matter...
I second what DoubleL said. I've had 2 regular OEM pad changes until I found out about the low dust alternative a couple months ago. When I finally had to change my pads over a month ago, I used the low dust ones and couldn't be happier. I'm actually motivated to clean my wheels since I know they won't just get covered in dust in a couple days. I haven't cleaned my wheels since the pad change and I can't even see any dust.
rselby
IS F (2008-2014)
22
02-23-16 06:32 AM
