Need help asap oem shock installation
Hi guys I really need some help with my rear shock installation. I'm switching out my coils and going back to stock. I followed the "Lower your isx50" diy but it's not going so well
I started on the driver side rear shock and am having some problems get the lower a arm back in place. I put the rear shock in but the bottom of the shock wont line up with the holes on the lower a arm. All the other bots (top 3, 2 on the side) are in the right place and I'm pretty sure this is the right side shock Here are some pictures:
http://www.flickr.com/photos/44644310@N07/8149787132/http://www.flickr.com/photos/44644310@N07/8149787132/ by http://www.flickr.com/people/44644310@N07/, on Flickr
http://www.flickr.com/photos/44644310@N07/8149787070/http://www.flickr.com/photos/44644310@N07/8149787070/ by http://www.flickr.com/people/44644310@N07/, on Flickr
http://www.flickr.com/photos/44644310@N07/8149787158/http://www.flickr.com/photos/44644310@N07/8149787158/ by http://www.flickr.com/people/44644310@N07/, on Flickr
http://www.flickr.com/photos/44644310@N07/8149787190/http://www.flickr.com/photos/44644310@N07/8149787216/http://www.flickr.com/photos/44644310@N07/8149787216/ by http://www.flickr.com/people/44644310@N07/, on Flickr
http://www.flickr.com/photos/44644310@N07/8149787190/ by http://www.flickr.com/people/44644310@N07/, on Flickr
ANY HELP WOULD BE AWESOME!!!! THANKS!!!!
you need to place the bottom in first you might need to use a rubber mallet to get the bottom to fall into place as it gets really tight where it needs to be to line up....put a jack under the rear control arm and jack it up until your top 3 bolts go into place...if you have the top lined up first thinking the bottom will go in it wont, if you notice the control arm inside widens and gets skinny - for a reason
