07 Lexus IS350...Full Hotchkis Suspension Installed Pics
Just to show two simple pics of the
Hotchkis Suspension Complete suspension kit installed on my 07 Lexus IS350
The kit comes with (info taken straight from Hotchkis)
Lowering Springs
Front Coil Spring Rate = 350 lbs/in.
Front Drop = 1-5/8" (41mm)
Rear Coil Spring Rate = 380 lbs/in.
Rear Drop = 7/8" (22mm)
Front (32mm) and Rear Sway bars (19mm)
Bascially identical to the F-Sport suspension kit, and price is slightly less...
installed without any problems. Ride quality is comfortable and nothing overall harsh, handling improved drastically over stock. Fit and Finish awesome, no fitment issues.
Best thing about the lowering springs, is that there is an optional aluminum spacer for the front, to raise the front if you find that advertised drop without the spacer is too much.
In my case, this is installed without the optional aluminum spacer
and on too the pics:
oh and its pretty much settled, driven approx 1800 KM already
Lowering Springs
I have a 2011( 250 RWD), you think it's worth, I do not want an aggressive drop (I like the F-sport). this is like, where did you buy in toronto????? thanks
Application Guide:
06-08 Lexus IS250 RWD
06-08 Lexus IS350 RWD
Additional Information:
Will not fit 2009 IS250/350 or AWD Models
Application Guide:
And I dont see any difference with the later model IS350, seeing all applications for lowering springs say 06 and later model applications for both isx50 models
jgarrido check PM...sent you all info...
As per requested...last pic at the passenger angle:
ModInJapan
CL Vendor Products for RC-F
06-22-18 01:44 PM
dewso1
08-06-12 06:10 PM
