Quick question: Toe and camber correlation
I recently had an incident with my car which resulted in messed up toes on my car.
I plan to run 19x9 and 19x10 +5 rims on my GS which I was told it will sit flush.
I understand that adjusting the camber will change the toe, but the wheel set up is currently not sitting as I expected so question is, does toe affect how much camber I can get? Will adjusting toe allow more negative camber?
Camber is currently maxed out.
No toe will not affect your maximum/minimum camber range. If you want to gain more adjustment to your camber/toe you should purchase either Battle Version or FIGS rear adjustable camber arms and toe links.
IMHO wreck or not these are must have upgrades for rear suspension.
