IS350 Caliper
I have a 08" IS250, I would love to get rid of that small caliper that's on the front...
If I do order the IS350 front calipers, would the install be just a swap? also I'm getting a bigger rotor as well, could I just take the old ones off and just put it on easy as that? or is there any other modification that I need done in order to make it right? Thank you
Also is the REARs on the IS350 similar to the 250s??? and would there be a difference if i have the 350 caliper/rotor in the fronts?
the IS350 has a slightly bigger rear then the 250. I just picked up some front and rear 350 kits. Check the classified section. here is a link to a fellow member selling them now https://www.clublexus.com/forums/is2...-complete.html
