suspension mods
Old 11-30-12, 07:50 PM
c2gs
c2gs's Avatar
Default suspension mods
Hi guys, Im new and finally found a gs300 black on black .
Believe it or not I waited 3 years to find the perfect one and finally got one.
Anyway I just ordered some Megan LP coilover and my question is what other suspension parts do u guys suggest in replacing? What parts are a must change?
Thanks in advance
Old 11-30-12, 08:08 PM
AEeighty6
AEeighty6's Avatar
if you are planning on lowering your car...and maybe someday slamming your car...I would get the toe links...to correct your rear toe...it is not the camber that destroys the tires its the toe...I would also get lower ball joints...dont let it fail on you...good luck!
Old 11-30-12, 08:32 PM
c2gs
c2gs's Avatar
AEeighty6 > I am planning to slam it after winter, just collecting parts for now and doing all the neccessary maintenance.
so do u know what brand is good for the toe links? an good website to buy from?
I read and saw pics about the ball joints too..****t thats some serious damage when its fails...so just new oem ball joints is fine?
Old 12-01-12, 07:55 AM
LuxuryGS3
LuxuryGS3's Avatar
Thanks in advance
Here's all that I SUGGEST when running slammed for a full suspension overhaul. Do all of this and you will not be dissatisfied with your choice to drop so much money on your suspension.
-: Moog LBJ's
-: Moog Outer Tie Rods
-: New Steering Rack Bushings
-: TRD Sway Bars
-: FIGS Front Sway Bar Endlinks
-: FIGS Rear Sway Bar Endlinks
-: FIGS Front RCA's
-: Battle Version/FIGS Rear Toe Links
-: Battle Version/FIGS Rear Traction Links
-: Battle Version/FIGS Rear Adjustable Rear Lower Control Arm
https://www.rockauto.com/ -- Moog Parts
http://lexus.sewellparts.com/parts-c...S300-1998.html -- Steering Rack Bushings & Sway Bars. Sign up as a CL member for a nice discount.
http://www.shopfigs.com/v1/ -- FIGS Adjustable Links
http://battleversion.com/ -- Battle Version Adjustable Links
Old 12-01-12, 08:15 AM
blacksedan
blacksedan's Avatar
wow, thats a huge list of parts!
Old 12-01-12, 11:04 AM
LuxuryGS3
LuxuryGS3's Avatar
I like to believe that there is a correct way to build a car starting with the suspension first. Coilovers, aftermarket adjustable links etc.. Doing these things can keep you from having to run into a problem later on because with the adjustable parts your car will be able to withstand the daily abuse of being slammed. OEM parts are not build to handle such abuse. IMO, build up your suspension THEN go slam your car on whatever wheels you choose, because if something snaps under your car while you're driving and things fall off or break etc then you have nobody to blame but yourself. There are resources out there to make your car more reliable when driving slammed, use them, if you don't and you rush well then you always run the risk of a problem occurring.
Plus who doesn't want their car to handle like a beast.
Old 12-01-12, 11:14 AM
nap
nap's Avatar
nice point..
Old 12-01-12, 09:38 PM
RikTT
RikTT's Avatar
LuxGS is right on point. Couldn't have said it better
Old 02-08-13, 12:25 PM
c2gs
c2gs's Avatar
Just bought :
- FIGS rear toe links
- FIGS adjustable outer tie rod end with bump steer spacers
- moog ball joints
-MEGAN EZ COILS
Question is do i still need RCA'S? for front and rear?
I haven't installed parts yet as I am still collecting parts and trying to find some rims . Work Euroline dh or any jdm wheel that style , Ya i know it's been done and played out lol but i love it.
Old 02-08-13, 12:27 PM
1sWt2GS
1sWt2GS's Avatar
welcome to the forums, post up some pictures of your car, i definitely wanna see it.
Old 02-08-13, 03:15 PM
c2gs
c2gs's Avatar
No pics yet bro just collecting parts for now...I'm gonna install everything once I find rims , dont really wanna drop it on stock 16's
juniorhash
Suspension and Brakes
13
09-24-20 09:56 PM
Settra
11-29-15 01:32 PM
PlotPoint
17
11-22-13 08:24 AM
white_ls
02-21-11 07:34 PM
Mr Jokster
09-24-09 11:06 AM
Quick Reply: suspension mods
